![]() lcyq 等级:三级士宗br /> 累计积分?2 可用积分?2 |
楼主 发表于:2017-03-21 17:08:58
用途概述: CSI-II智能型碳硅分析仪?/span>用于炉前快速测宙/span>灰铁、玛铁、球铁、蠕铁等原铁水的碳当野/span>?/span>碲/span>?/span>野/span>?/span>硄/span>?/span>野/span>、球化率+/span>抗拉强度及硬度判宙/span>等、/span>该仪表操作简单,测量精度高,稳定性好,广泛应用于冶金、铸造、机械加工等行业、/span> 功能及特点: u测量数据可自动储存,可随时调用历史测定的碳当量、碳含量、硅含量及曲线趋势图,便于分枏/span> u可测球化玆/span>叉/span>抗拉强度及硬度判宙/span>筈/span>、/span> u可根据测定的成分含量、已设定的铁水量、目标成分及材料留存率自动计算材料不足量,便于炉前快速调整 u17寷/span>液晶屏幕显示+/span>外接操作鼠标:span style="font-family:Times New Roman">USB数据接口、数据保存、数据库查询及输凹/span>、/span> u具有输入/输出和通讯功能,可与计算机通讯 u可设宙/span>8杠/span>不同检测线,以适应不同种类的应用场合。具有准确、可靠、测定范围宽的特点、/span> u测量速度快,测量时间不超迆span style="font-family:Times New Roman">3分钟,便于炉前成分调整、/span> u冷却曲线和测量数?span style="font-family:Times New Roman">CE?/span>C%?/span>Si%?/span>TL?/span>TE同时显示,清楚直观、/span> u测量范围9span style="font-family:Times New Roman">C%倻/span>2.1-4.2% Si%倻/span>0-20% CE2.5-5.0%球化率倻span style="font-family:Times New Roman">40-100% u测量精度9span style="font-family:Times New Roman">C%倻/span>±0.039%Si%倻/span>±0.10% CE±0.047%球化率倻/span>±10% u外形尺寸9span style="font-family:Times New Roman">400*400*230mm(长*髗/span>*宽) 重量9/span>24kg外包装尺寸:550*320*490mm(长*宼/span>*高) |
